If you think of the rads as rungs on the ladder with the boiler connected to the two sides, where do the troublesome rads occur up the ladder? Are they the top two rungs or nearer the bottom?All rads are hot or very hot except for the two troublesome ones. Neither of these have even a warm inlet pipe.
How many rads do you have?
My faultI cant quite picture the boiler in that way.Perhaps it would be connected to the two sides at the bottom?
Probably easier to pipe it that way. Eight rads is not a lot and should easily be handled by a 15/50 pump. What pump do you have and what setting is it on?In that case these rads are the top rungs. I've 8 Rads. Weirdly (ask the builder) the heat is going to the new downstairs rads, then upstairs, then back down to the last two rads.
My faultI cant quite picture the boiler in that way.Perhaps it would be connected to the two sides at the bottom?, I should have said the boiler was connected at the bottom
It's almost definitely a balance problem. Correct procedure is Here
Wot, no flashFirst time to upload a pic, fingers crossed.
