HI, Just after a bit of info.
I have (had) a Potterton 40 boiler which was covered by british Gas Homecare. It was serviced last week for it annual check up where it was condemned due to a hole in outer case (one of the pipes into it had been dripping on to it and it had rusted the case).
Anyway my question is what should the gas man have done? With mine he capped the gas (fair enough), removed all the wiring putting them into a box (why?) and also removed the fuse from the isolator switch. Is this normal? when I had it replaced the wiring became a mare and needed an electrician which would not have been necessary if the pattern of wiring could have been seen in the one which was condemned (I had a newer version put in so like for like). Does anyone know if this was all necessary?
Also does anyone know if this corrosion should have been spotted maybe a few years ago when they have service it every year for the last 4, would I have any comeback on them as they should have seen it before it happened and cost me £1500 for a replacement.
Sorry to waffle on but any advice would be great.
Ta
Ta
