I went to the local plumbcentre to get a replacement room thermostat for the standard british gas fitted stat, and they supplied me with a honeywell DT90E but I am not sure if this is able to be swapped over. The present stat has three wires, one white which I believe is the neutral, then a alive and a black wire with a brown sleeve which I believe is the call for heat. on the honeywell unit it has A B and C connections and very poor instructions for fitting unless you are in the know.
So my question is can this stat be fitted to the present system and if so which wire goes where.
It is a standard worster boiler not combi with the british gas standard time clock.
thanks
thanks
