My mother's Worcester Heatslave 2+ floor-standing boiler has a flue which enters the wall at a 45 degree angle and then vents into an existing chimney. To the best of my knowledge, after entering the chimney breast, there are no further kinks/angles for the exhaust gasses to contend with. The only way is up!
My mother's boiler needs replacing and the two heating engineers she has contacted seem unwilling to replace her existing set-up with a similar one. They say that a flue which enters a chimney breast is not safe or permissible. This will add a lot of extra cost to the boiler replacement and be far more disruptive as a separate flue will have to enter the ceiling directly above the boiler, be taken through the attic void and an opening made in the roof. Expensive!£££ It would be much simpler (and therfore cheaper) to use the same exhaust route as the existing boiler - i.e. vent into the existing chimney.
What I'm interested to know is this: is my aging mother being spun a line to suit the economic interests of the plumbers she has contacted or is it now actually illegal to run a flue into a chimney breast?
(I am assuming that the chimney has a modern flue liner so please could you make the same assumption in your reply).
Many thanks!
Many thanks!
