Hi
We've moved into a family members empty 200 year house that needs a bit of work done to it. I thought I'd do the bathroom first and having stripped it bare, removing several layers of 2x1, chipboard, asbestos, plaster and lathe, then getting rid of massive wasps nest and capping off the bath and sink taps last night we have no hot water, and now no heating either.
The weird thing is that last night the heating was working and the only thing that happened after that was an old tap valve coming from the pump burst. I replaced it this morning and now even the heating doesn't work.
As far as I can gather, it is a vented system. In the roof level there is a pair of small, square tanks, which I imagine are the F&E tank(s) with an overflow type pipe going out onto the roof. In the bathroom (next door) there is what must be the vent pipe which goes vertically up through the roof an into an umbrella handle shape.
The pump is gently vibrating and the pipes on the outlet side of the 3 way motorised valve are both hot, but there is no hot water or heating anywhere. There is no water coming out of the hot water taps at all.
The pump type is a Grundfos selectric UPs 15-50 130
The boiler is an Ideal standard E-Type CF 100 Conventional Flue Boiler
Anyone got any ideas what could be up?
Cheers
Paul
Cheers
Paul
