Hi Gang
Going to try and give as much info as possible as i know you guys have the best knowledge on the net.
Right to start with been to see a client who has low mains water pressure. I have tested pressure at kitchen sink and getting 3mbar still and about 12 liters per minute.
They have 2 big storage tanks in the attic that feed vented 150 liter hot water cylinder and cold supplies to bathrooms.
There is a basin and kitchen on ground level, a hot water cylinder, bathroom and shower room on 1st level. The boiler is on ground level and gravity fed, header tank in attic.
Tested the flow rate on basin on 1st floor and only got 6 ltr per min
The shower is pumped so not bad there.
The client is just wanting good pressure at all outlets what is the best way to go
Thanks All
Thanks All
