Limit Stat
6 Nov 2009
Lincolnshire
Can anyone please advise what a limit stat is? Can something be reset and if so how? Unfortunately, we have been without hot water for two days, not that the landlord seems to be bothered. At least the weather is not too bad and I'm heavily pregnant so the heating is not a necessity. Any help at all would be greatly appreciated.
high limit or overheat stat is a safety device
it turns off the boiler if the temp rises over its pre set limit
some can be reset some reset themselves
some die
boiler make / model :?:
Boiler make and model would help.
The high limit stat has probably tripped, but they do that for a reason, and re-setting it may not do any good.
Get onto the landlord, or the letting agent, and if that don't work the Council.
If you open the door is there a red light on, on the burner box at the bottom, if so press it in.
There is a reset button that looks like it could be illumated red but it isn't on and it says 'only reset twice'.
Yes silly question but always one that has to be asked!. There is about half a tank of oil available.
There is a rest button that looks like it could be illuminated red but it isn't and it says 'only reset twice'.
Does the boiler start to run, or just sit there doing nothing.
