ideal mini temp gauge not rising fault
29 Oct 2007
Coventry
hi guys hoping you could advise
i have an ideal mini c24 boiler, the pressure gauge which also includes the temp gauge the needle does not rise,
when the hot water is running or if the central heating is on the temp gauge needle does not rise to the temp it should be it stays at 0 degrees
a week ago it was working fine but now the needle does not show what the temp is - no movement
the boiler pressure gauge needle works
any ideas as to what the fault could be?
does that help FFS
if you can type/ask for advice, surely you have heard of Google
try ideal+boiler+spares :idea:
GG is on the voddie again
You really dont need a temp gauge on the boiler.
Does the boiler work?
Is your hot water hot?
Does your heating keep you warm?
If I want to know the temperature of a boiler, I use a very sensitive piece of equipment. My finger.
i just thought it would be appropriate to replace, to all your questions "yes" i shall leave it as it is then and use my finger , cheers ;)
faulty capillary
pip pip sorry about that old chap, meant this correct prognosis of the fault with your temp/press gauge incorporated within your combination hot water/central heating gas fired appliance
still a fud btw
