Extending cables underfloor
17 Jun 2009
I'm at a job where i've been asked to extend same cables, now unfortunatly this must be done under the floor. I know that Junction boxes are now not allowed, and i would use crimps in a choc box, but recently i found out that apprently crimps aren't very good on solid cables and only work well on stranded cable. Whats the best way then to make these connections and is what i've heard about the crimps true or would it be perfectly safe to use them?
Edit: Just seen a different thread on the same page answering my question, only problem is one of the joint boxes has more than 1 pair of cables in (a spur), so what then would be the best option?
If you have access under the floor why can't the cables be replaced with ones of the right length?
"Now"? They've had the same restrictions (not prohibition) on their use for at least 18 years.
Where did you find this out?
They'll be fine if properly done.
Replace the cables.
As i only have access to a certain part of the floor area.
Looking around on another website
Then this is what i shall do.
Replace the cables.
Is there any other way as i really son't no if i'm going to be able to replace it because of the access i have to certain parts underneath the floor. I take it you can't put 3 wires into one crimp?
Are they those push in connectors you sometimes find in lights? If so even if they did comply then i wouldn't put them in as i wouldn't feel safe.
But thanks anyway.
They are, and I don't blame you.
And IMO (and others too) the manufacturers are taking a flyer on this "maintenance free" malarkey when that concept doesn't appear in the regulation concerning concealed joints.
The Ashley ones push in, there is obviously a barb arrangement because you can't then withdraw the cable, once all connections are in place you push down the tab on top with a screwdriver, this compresses the joint and makes it permanent, much like you do do when squeeze up a crimp.
Reading back through this forum a few years ago crimps were being frowned on as unsuitable for permanent joints, funny how times change.
