instead of giving information in little bits why dont you tell us what boiler you have , what type of controls , vented cylinder or unvented, anything else playing up (like programmer flashing)or anything changed recently, or anything you feel might be important
the boiler is aback boiler it has a room stat cylinder stat and two channel programmer when heating or hot water are turned off on programmer ie lights are off the pump still runs and seems to overide the boiler stat it continually runs , the room stat or cylinder stat do not make any difference the only way to stop it is to cut power.
