Just go to your nearest pound store and buy some torches - they will work just as well as your idea.
Can you clarify where you got the 1 tx for 1 lamp recommendation from?
Probably from me, as that is what I recommend.![]()
Listen to that man, hedownlights!![]()
The lamps are rated in watts because they are purely resistive.
Can you guys tell me if these transformers will draw the maximum rating all the time? This wording in the instructions has confused me:
"To calculate the toal load for dimming, add the wattages of all the transformers you are intending to dim and choose a dimmer with a rating to suit."
I've got the 0w-50w versions and will be using 20w lamps in them. But does the wording above mean that the transformer will always be drawing 50w regardless of the lamp wattage?
If I have 10 20w lamps (and therefore 10 transfomers - I'm using 1 tx per lamp) does that mean I need a dimmer that can handle 500w or 200w?
Thanks[/b]
