Fireplace
18 Jul 2006
Sussex
Hi
We have just had a gas fire taken out and want to use the fireplace as an open fire. We are also having all the artex in the room skimmed and were wondering how we can go about finishing off the fireplace.
As you can see from the pic, we have a timber mantel piece and original tiles as a hearth. We'd like to stick with the original tiles - also modern hearths don't seem to be deep enough to cover the tiles.
Basically, we'd like to have a plastered finish but realise that it would probably crack from the heat. Is there a way of doing this?? some sort of fire-proof finish??
Any help, much appreciated.
Graham
a fire log is the insert that has been built into the fire hole that you see when you look at the opening in your chimney breast
as long as the flue has been checked out and is in good order the fire log will do the job of containing the heat of an open fire.
hi re-read your first post, you don't mean the fire itself do you
you mean the surface finish to the artex covered tiled surround don't you, oops :oops:
Yeah, the artex is going to be skimmed, but I'm guessing if we plastered up to the edge, it will crack from the heat.
Also, we've had a smoke test that passed - just need the chimney swept.
I can only surgest looking for a fire surround to sute the job
there are plenty out there to sute your taste and will give you something to plaster to as well perhaps, sorry if this answer doesn't inspire you
I did my fireplace out a bit back and grabbed a bargain surround and mantle for £50 of an add in the paper, best of british.
Correct; Gypsum base & finish plasters will not stand heat much above 50 degrees or so without cracking & blowing; Artex probably wont either (but not sure) so it will probably have to come off. The wall in the area 200mm to the sides & as much as 500mm above the fire will exceed that & it’s why open fires, log burners & solid fuel burners generally some sort of stone/slate/tile surround.
Use a heat proof render base (or a sand/cement/lime render base) around the fire to tile/fix a surround on to but if you want a plastered finish up to the fire, use a heat proof finish plaster over that;
http://shop.vitcas.com/vitcas-heat-resistant-plaster-16-p.asp
Looks like you may have a suitable fire back already in there, was it originally designed as an open, solid fuel fire? If so, the constructional hearth (the bit below those tiles) should also comply with current Building Regs. but it should be checked. Have you checked the flue is suitable? If you have a gas flue liner it won’t be.
There's no flue liner. Built in 1935 so I assume was originally used as open fire
Things have moved on considerably since then & if it's as old as that you need to get it checked for compliance with current Building Regs. You also need to be aware that even though your converting back to what was originally there, what your doing is notifyable work & must be certified complaint, either by a HETAS registered installer or by submitting a Building Notice to your LABC.
