My central heating system is a normal old fashioned one, ie not combi or condensing boiler. It's a glowworm boiler. I know nothing about how central heating works but I can see that there's the pop-out switch on the boiler and there's the on and off switch on the boiler (both under the slide off panel, there's the wall mounted thermostat, there's a thermostat on the hot water cylinder, an immersion heater switch on the wall (which I've never tried to use anyway) and whatever else I've missed. My problem is that I can't get my radiators to come on and stay on.
Fiddling about with some of the aforementioned items has had a bit of shortlived success but normally they stubbornly refuse to come on or the pilot light comes on and the boiler starts when I fiddle with some things, but goes out pretty quickly ie stops with a minute or so. What am I doing wrong? The hot water heating side of the equation works fine, it's getting the boiler to start and heat the radiators that's bombarzling me. Are there some optimum settings/basic rules that I'm not following? Help!
