I have a leaking flush toilet water inlet in a recent-build flat. It started leaking and I thought it was a straightforward case of changing the fibre washer.
I found that there were previously two fibre washers and replaced them. Switched on the water again and it leaked. I have since tried several times to replace the washers and even tried using rubber O rings. The problem seems to be that the copper pipe does not really want to extend all the way to the cistern inlet and is exerting a lot of force away from it. The thread of the inlet seems to be still intact although it is quite difficult to get the thread lined up with the nut. I have to loosen the inlet so it can move to meet the pipe.
After several attempts the thing still leaks like a sieve. I'm wondering if there is any widget I could use to fill in the space between the inlet and the copper pipe so that it isn't such a task to bring the two together long enough to try and tighten the thread. They maybe sit about 1cm apart when disconnected.
Here is a picture of the inlet with the leakage points shown in red. The nut looks a bit lop-sided which probably explains why it is leaking now but this is just how I left it before I gave it up as a bad job.
