Ceiling light advice
13 Nov 2008
Avon
Tomorrow i need to replace a ceiling light but need to check one thing before i do the job.
In the ceiling rose i have the following.
3 reds in a block connector marked L
1 single black in block connector joined with blue wire from light
2 blacks in block connector joined with brown wire from light
1 earth in block connecter marked E
As the new light is metal i was going to fit the green/yellow wire from the light to the 1 earth block marked E and just fit the colours like for like as i have mentioned above blue/1 black & brown/2 black.
BUT
I have seen a wiring diagram where the above stays the same but the blue & brown wire from the light have been switched around meaning 1 single black/brown & 2 blacks/blue ?????
I would like to ask before i do this just to be sure.
Do you not have a multimeter and a good understanding of how lighting circuits work?
For some reason they've connected what should be the the neutral wire from the light to the switched live, and the live to neutrals.
Won't stop the light working, but there's a minor safety risk with full-sized ES lamps, if that's what it takes, in that if you change the lamp with it switched on you could possibly touch the screw part, which in your light will be live.
Swap them round so that brown is live and blue is neutral.
That seems like it MAY be wrong.
Whatever you do, make sure you mark and remember, what Blacks are together, before you start.
I am leaving the existing wires in place.
I am only removing the blue & brown wire from the old light the fitting the new light to the existing wires.
My understanding is the 2 black wires are the loop wires "from previous light/to next light" and should have the blue wiring connected to it.
The single black wire is the switch live so the brown wire is connected to it.
I think this is right but i asked first.
So the brown i have fits 1 as 2 is the switched live.
The blue goes to 8 as 6 & 7 and from the previous & next light
