B
Bodd
Hello All
I need some opinions before I tackle this job.
A customer of mine has a 2 year old heating system that they say has never got that hot. It consists of:
1 x Valiant eco tec plus 624 RI and
1 x Valiant eco tec plus 618 RI
They are situated in the converted loft serving 20 radiators and two 210 litre open vented cylinders.
The house is a large 3 floors (5 levels) 1920's style with a cellar.
Problem is after balancing I can only get 4 or 5 rads hot as you would expect maybe another 5 Ok'ish (but not exceptable) one that will not heat up and the rest that get luke warm.
I have put a balancing valves on the cylinders.
I'm not lost on this and have my ideas but would like some second opinions.
I have not done no calculations but recon the the boilers are up to he job a 28mm gas supply does go a long distance but all the way to the boilers.
the boiler flows do have a non return valve fitted on each, for some reason.
I could remove these but don't feel it will make much difference,
I could fit an additional 15-60 pump to help push around the system
I also get the feeling the pipe work could be undersized.
I have not investigated this in any great detail but can see 22mm is leaving the boilers via a 28mm manifold as such.
Each of the 3 floors are zoned with there own thermostat as well as the 2 cylinders.
I suppose there could be partial blockages.
The pressure was low on the gages so I had to top up.
I'm would love to get my teeth into this but also don't want to waist time on a job without a satifactorie outcome.
Hope I have not bored you.
Bodd
Bodd
