boiler cuts out
boiler works fine until the hot water comes on then the boiler shuts off been working fine uptill two weeks ago any ideas
Just had same with mine (ideal c80ff).I tested everything then opened up the ignition PCB which lives on top of the gas valve , was all burnt around one of the resistors , got a new pcb and now working fine.I have had this as a problem for a few years now ie: DHW causing system to lock out, and having to put CH on to help me run the bath etc.
Consulted a electrical guy I know, and showed him the old PCB , he said that it had been a dry join that was arcing and that if would cause a intermmitent fault, which would over time get worse till it failed , which it did just befor Xmas .
Now I can defrost the Wife and KIds
YB
So it's not worked for 2 weeks, then you expect to get it repaired xmas eve :roll:
