help please: how to join 2 laminate panels together? :)
27 Dec 2009
Hello:)
I have 2 rectangular laminate panels that I want to join together to make a bigger rectangle. It'll be the door to my cabinet.
I've read this guide: http://www.diynot.com/pages/ww/ww017.php#a2. But I'm unsure how to go about it? can you please explain? maybe a simple illustration?
thank you very much for the help :)
what size are you talking about[thickness length and breadth]
are you talking 15mm conti board without a frame with a frame
or are you trying butt join side to side
this one. thank you
ok you havent answerd my question on material size or if a frames required so i will assume its a normal kitcken cabinet door size
http://www.diynot.com/forums/viewtopic.php?p=1451615#1451615
so all you will need is 2 mending plates
http://www.toolstation.com/documents/search/index.html?searchstr=mending+plates&submit=Go
as each part will have 2 or 3 hinges they only need holding to the same arc
any other solution will require an expenditure of between £15 to£60 on the basics to allow using buiscuts or dowels :roll:
It seems the material is made of MDF. and no frames are required.
thanks big-all! :)
