Yes it does.Replacing a toilet does not require notification.
Bas, any chance of saving me looking through the whole document by telling me where it says this? Somewhere in part G, I guess. No catch - seriously interested.
It used to be acceptable to have SP fuses on neutrals
When was that?
other than BAS is a closet trekkie
No he's not, he's a real pointy eared vulcan, or maybe he's an elf?
You are missing the point that I am trying to make, namely that your point is illogical, inconsistent and unreasonable.
Only if the capping is suitable for [use as] a cpc.
Schedule 2B
DESCRIPTIONS OF WORK WHERE NO BUILDING NOTICE OR DEPOSIT OF FULL PLANS REQUIRED
1. Work consisting of—
(j) replacing—
(i) a sanitary convenience;
(ii) a washbasin
(iii) a fixed bath;
(iv) a fixed shower bath;
(v) a rainwater gutter; or
(vi) a rainwater downpipe,
where the work does not include any work to underground drainage, and includes no work to the hot or cold water system or above ground drainage, which may prejudice the health or safety of any person on completion of the work.
Getting back to the original problem, however, if it were me I wouldn't be worrying about the ridiculously over-zealous RCD requirements of the 17th edition and would just install the T&E without RCD protection if I wanted a non-RCD outlet. And I can't think why I would need it, but if I were completing an installation certificate for myself, I would note it as a departure.
However, if you want to argue the point about departures being only for non-compliance with regulations where such non-compliance offers a similar level of protection (however that's defined), how about this?
Buried SWA is considered acceptable without RCD protection. We all know that SWA isn't going to stop a nail or a drill, just make sure that said nail or drill is in contact with the earthed armor before it has a chance to reach a live conductor inside.
So what if you were to fit steel capping over T&E and securely earth that capping with a pigtail at the backbox of the socket? Would that not give the same effective (non-)protection from nails, screws, or drills as SWA?
I'd have thought so. Thanks Col, I thought I was going mad.isn't a toilet a sanitary convenience?
Schedule 2B
(j) replacing—
(ii) a washbasin
(iii) a fixed bath;
Hibbo said:I know that flexshield was acceptable for running outside of safe zones under the 16th, but not in the 17th. Would it be considered an acceptable 'departure' to use flexshield for a non-RCD run?
They could be, and it would certainly help, but then you go into the realm of the other posts with respect to informing people of the uses of nearly every other commodity. So I won’t suggest they do that.But not all - why aren't you complaining that people aren't told about the notification requirements if the windows are going into a dwelling?
Exactly, if people are certain to be flouting the law then they need to be made aware of it. Most people who drive with no insurance know they are doing so illegally. Most who buy a CU from a home improvements chain won't.You think that in some areas it is reasonable for a retailer to act as if people will be aware of the law, and in other areas it is not, based on what you think most people will have come across.
