Hi, please help!
I have just had a vaillant EcoTEC Plus 428 boiler fitted to a old system in my new house. the 25 year old potterton was on its last legs, at the same time a new twin coil DHW tank fitted into the loft (twin coil for the old solar system).
I requested a wireless VRT360f timer as I am used to this from my old property. the fitter also fitted a VR65 to hook the whole lot up.
now this has been fitted against my better judgement over the christmas period, three days before christmas eve fitting the boiler a new tank and systems and a day after to hook up the solar system to a new pump station.
everything was sort of okay over christmas eve to boxing day period, I say this as the boiler seemed to be on and off a bit, hot water was fine but the heating sort of needed a 'push' to get it up to temperature, but all the electronics seems to work fine. fitter turned the 28kw down to 8kw
now since the fitter has been back to sort the solar system out and 'tidy' the wiring he has left me with a fully manual system - i only noticed this after he had left and now he says he cant help and has arranged a vailliant service call. he turned the boiler up to 20kw - seems about right from what I have read on this site for 13 rads (?).
now since he left on Monday the controls on the VRT360f are dead, and as I said above I am opening and closing the valves manually, the boiler and pump seem fine. i have a flashing green light in the VR65 which means it has a com's issue, I have replaced the rubbish cabling between the boiler and the pump/VR65 with a new 5 core as the original was various odds and sods of cabling that was originally in place. yesterday I replaced the VR65 and still the same, so this pointing to be either the boiler or the 360 programmer.
the Vaillant guy is coming on Tuesday, but I would like to make sure everything else is fine and the fitter has not missed anything silly, and would love get my heating back to auto.
any thoughts out there, any advice would be much appreciated..
cheers and have a good new year
