servis washing machine leaks from the bottom
19 Dec 2009
Hampshire
hi i have a servis washing machine that is leaking from the bottom i can not see where its coming from can anybody give me any advise on how to find and fix the leak any help will be much appreciated
regards steve
Can you lay the machine on its side, and have a look at the rubber pipe that comes from the drum bottom and connects to the pump or filter? These are the most likely areas.
John :)
John :)
thanks john i've tried that and the pipes look fine i am now puzzled to where else it could be coming from :?
Hi John and Steve,
I too have that particular problem, have also laid it on its side and cannot see where the water is coming from. There is no apparent leak from anywhere visible! :? :( :x
Steve, did you find your problem, or, John, have you any other suggestions as to where to look - it's very frustrating :!: ,
Thanks guys,
Donald
Remove lid and shine a torch down inside while mc is in use ,be carefull mc has power on.
