cooker stickers!!
8 Jan 2010
Yorkshire
just moved in to a new house has a fitted hob and oven however no instructions at all on the cooker ie all numbers and temperatures for the oven, heat settings etc have all rubbed of. tried e spares they dont stock the stickers or what ever... please help getting annoyed
most are screen printed, unfortunately mrs housewife uses brillo and all the chemical cleaners that remove the printing ink!
make: ignis
Model no: AKL828/IX
having a bit of a nightmare with this one sorted most other problems like remote centrall heating controller not working. found the instructions on line but this cooker beyond me. might just try and get a new one does anybody recomend a good make. dont want ignis if all markings are going to rub off lol.
many thanks.
My now 4 year old “quality” custom built range has (had!) them over a stainless steel face plate & I made a point of asking how hardwearing they would be. I was told it would not be a problem but they only lasted about 2 ½ years & the faceplate is now almost blank. I rely solely on memory but am considering recalibrating with a cooking thermometer & some Letraset. Scourers or strong chemical cleaners (which will also strip a factory applied lacquered finish!) were not used, only washing up liquid & hot water.
Unfortunately screen printed & transfer decals now seem to be commonplace but I would avoid them at all cost in future; they will eventually wear off no matter what the manufacturer tells you.
Letraset
You are joking,
Well it was only an idea I had to at least put some indication back on the facia :roll: there seems to be no other alternative & the manufacturer isn't interested. I have used it before & was thinking of just a few indicating marks, nothing as sophisticated as numbers; maybe better than having no indication at all. It probably wouldn’t last long though. :lol:
Better using a marker pen..just put a few dots & dashes, you can then mark inside a cupboard door what they are.
thank you all very nice of you all however now getting a new hob and oven touch control hob will keep instructions for the new one in case they ever wear off. but hopefully by the time they do wear off i will have learnt what control is what.
scrubbing and chemicals on facia panels is never a good idea
damp cloth of warm soapy water after a use is always enough.
if you let it get so dirty and ground on then your asking for problems.
The OP never said they did that, they inherited the cooker in that condition & I certainly don’t do it.
It’s all I’ve ever done & they still wore off.
That’s an inflammatory & rather stupid statement to make :evil: , how can possibly assume an individuals level of cleanliness from the thread :roll: . I admit you would be correct if it was the case but screen printing is not particularly hard wearing & the opposite is just as likely to be true.
I’m still living with it but it was never a problem for me & the OP has now bought a new cooker so your post is pretty irrelevant. :wink:
