Help please identifying conservatory gutter brackets
9 Jul 2009
Buckinghamshire
Hello. I had several of these gutter brackets break in the recent snow but I'm having great difficulty in sourcing replacements. They are from a conservatory but I'm afraid I don't know the make. The small tongue shown in the green circle has broken off in the red circle. The only identifying mark is "RS32790". It is a “twist in” internal (ie it sits in the gutter rather than underneath) bracket but does not appear to be Ultraframe, Global or K2. Any help with identification or more importantly, a supplier please? I will need about half a dozen.
Thanks for suggestion. However, they don't really look the same. They are screw-on whereas mine is twist-in. Any other suggestions welcome.
I'm afraid I don't have an answer to your query but I am in exactly the same position as you. I lost my conversatory guttering in the snow and need replacement brackets.
If you do get an answer, please let me know.
Cheers
Bryan
You can get it from ebay
http://cgi.ebay.co.uk/Conservatory-...emQQptZLH_DefaultDomain_3?hash=item439ced2625
btw do you know how to fix it, do we need to hire a specialist person or it is easy to fix
with regards
Bramfish
I needed RS32790 brackets I got them from Capitall Systems on 01386 421919 they were 1.40 each plus p&p and v.a.t.
They said that they had a few left yesterday.
Martin
Thanks people - they look just the ticket! So the answer for future reference is Wendland Roofing Systems. Parts ordered and hopefully problem solved.
In answer to FANWAR, the brackets slot in and the twist 90 degrees to lock. Make sure the surfaces are clean and possibly lightly lubricated. Best not do it on a freezing day as bits like this can get brittle.
I have had same problem with consevatory brackets RS 32790 and have obtained a very similar replacement from Eurocell. Thet are not exactly the same and have changed all the brackets and have 15 of the old brackets (RS32790) spare
I too suffered the same problem due to the recent snow.
For anyone in the Kent area you can get the clips mentioned from Eden Windows 01634 840999. :-)
you can get the brackets with that code stamped on them from the conservatory manufacturer amazon - part of amex holdings they will sell them separately
DBrown
would you be willing to part with your old ones. Have tried using same from Eurocell but are snapping my guttering rails.
Hi!
i have had the exact same problem! the snow caused the majority of the gutter brackets on my conservatory to break and trying to source replacements is near impossible, i've had such a struggle :( the code on the bracket is: RS32790 however the brackets from Eurocell with the same code are slightly different and dont fit!
having searched around and contacting numerous suppliers & companies i came across a company not far from me - Truly Conservatory Repairs, i dropped a bracket with them to see if they could source any and they did! yay! :D
not sure where they got them from but have added the link below if any of you are still struggling they may be able to help? worth a try anyway...
http://www.trulyconservatoryrepairs.com/
