shower wiring
23 Mar 2005
hi just wondering if you could put me mind at rest(hopefully).
the shower in the ensuite - the cable and pipe are next to each other in the studded wall,they are touching..the cold water pipe is copper then pushfit pipe the cable sheath is in perfect condition.....are there any safety issues here?
thanks
magico
Generally it's not good to have pipes beside wires. Lazy fitters have done 1 x hole for both services.
It's unfortunate, but since its not a hot water or hot heating pipe the prospect of cable damage due to heat radaition is none existant.
Hopefully the main water is earth bonded in the property, so should a fault ever surface then there's the safety of live running off to earth due to the bonding.
yeah the main water line coming into property is earth bonded.and as you say the water pipe is cold only so won`t cause any heat to damage cable sheath....
thanks very much chri5
cheers
magico
Well, slang it may well be but M8 could also refer to a specification.
It could be a cable installation method. It also could be relating to the short circuit capacity of the protective device that I was asking about.
You often see M1, M1.5, M3, M6, etc etc on BS3871 circuit breakers.
I am very well aware of all this text speak malarky and thats fine when you are trying to get your girlfriends knickers off by txt spk.
But I got a very terse and confusing response to my helpful question.
And I still don't know if he has an RCD fitted.
You must have the gift of the gab. I've never been able to get anybody's knickers off with text speak :cry: .
Perhaps if magico could e-mail me his girlfriend's mobile number? :wink:
AW c'mon Chri5, I thought you knew better than this. What a load of gobbledygook.
Best get your head around GN8...
... m8.
