facing problem regarding mdf surface any possible solution
21 Feb 2010
sirs
good day i am wood worker i am facing problem at this moment this is the flow of my work i use cnc router for cabinet using mdf board after that i am sanding it after i used vacuum press using pvc laminate the result is very bad the surface of mdf board with pvc laminate have a bubble some routing mark seen as well .any teqnique or pointers you can suggest me can i used primer or sealer for this problem if i can what type or kind . i am badly needed solution for this thanks. :(
Which CNC/Press are you using?
I already responded on another post to you on this subject. Use a moisture resitant MDF board or a high Density MDF board. This will help resolve the problems you describe.
Regards,
JR
Regards,
JR
SIR WE ARE USING "ORMA PM AIR SYSTEM VACUUM PRESS MACHINE"
HOW TO CHECK THE MOISTURE RESISTANT OR HIGH DENSITY MDF BOARD IS THERE ANY CODE THAT WE CAN USE TO ORDER THIS KIND OF MDF BOARD
Which company do you purchase the MDF from? please provide me with their details and I will follow up on this for you.
Regards.
JR
Did you manager to resolve the problem?
Regards,
JR
