A mate's brother skimmed over the top of the artex in our hall way.
At the time I removed the architrave for the loft hatch and PIR sensors but neglected to remove the ceiling rose for the lights so he's plastered right up to them.
I've scored the plaster around the rose and removed them and I now want to patch in the bare patch of plasterboard revealed behind them and install new ceiling roses on top of the plaster surface.
It'll need about 8-9mm of plaster.
I'm considering either filling in with some one-coat plaster that I have a bag of and then once that has set filling it till flush with easifill which i can then sand flush.
OR
Attempting to make up the whole 8-9 mm with easifill and then sanding flush.
Can anyone recommend one way over the other? Do I need to prepare the bare plasterboard (it was never artexed originally or skimmed over) in anyway? It's only a small patch the area of a ceiling rose.
Forgot to mention that drying time is a small issue as we'll have no lights in the hallway until the repair is complete and the new ceiling rose installed.
Cheers!
OR
Cheers!
