H
holmslaw
But if you alone are making the decision that would probably make it illegal. You should be using a permit and risk assessment system involving at least two other experienced people. And financial considerations should not be part of the process, let other people worry about the cost.
Paul, just checked the regs because I had a suspicion you were correct, but you're not.![]()
What you say is true for the 14th and 15th edition regs, but it has been dropped from the 16th edition (mine is dated 2004) and 17th edition regs.
Also, I've seen grey cables that could be pale blue, and browns that could be reds, seems the cable manufacturers conned the IET into not specifying BS colours.
I don't think many contractors used yellow or blue phase coloured cables for single phase sub mains. So your scenario is unlikely for pre 16th edition blue and black, but yes it could happen.
No person shall be engaged in any work activity on or so near any live conductor (other than one suitably covered with insulating material so as to prevent danger) that danger may arise unless-Read some more of the words, not just the ones that support your daft argument.
Is that the definition in the EAWR?No it does'nt, 'work activity' means 'repair, adjust, construct, change'.
From whom does an electrician get a permit to allow him to do testing in a customer's home?Electrical testing has always required a permit and risk assessment system.
Sounds like a good idea, wait for the 18th edition.![]()
Hi everyone!
I think this is a fairly simple question...Cheers!
That'll be the edition which also says you can do anything you like so long as you RCD it.![]()
