I had British Gas round yesterday to see if we could get cavity wall insulation, the house is a 4 bedroom detached built in 1988.
The BG guy said yes we are eligible for *free* cavity wall insulation but they could only do 3 walls because one gable end is less than 1.3m from the next door neighbour and is too high for ladders, the ground being ~1.5m lower on that side. He said they'd have to use scaffolding if they did do it which is £400, fixed price from BG, and not covered by the governments grant.
Now, after he'd gone I was thinking couldn't they do the fourth wall from the inside? Having searched online I have found one forum post saying it can be done from the inside. I'll have to ask BG on Monday if they're prepared to do it.
However, being a bit inpatient I was wondering if any of you nice people could help:
- Is it possible?
- Approximately, how many holes would need to be drilled from the inside for the one wall, the wall is a gable end with one window and one air brick. BG said the insulation would be glass wool.
- Could all the holes be drilled in the attic?
Thanks.
- Is it possible?
Thanks.
