Quick question,
Need to run a supply to my garage soon to replace the buried 2.5 T&E which is existing
Was planning on a 16a type 2 RCBO on main house CU, 4mtr's of 2.5 T&E joining 8 mtr's of 2.5 SWA inside the house through to the garage. The SWA will be fixed to a wall surface along it's entire length into the garage. From there it'll feed a pair or three double sockets. The sockets will run a 150w light, small freezer, and a radio most of there time, but occasionally other tools and a pressure washer.
I've completed the part P full scope (heating engineer) so have some knoweldge, but not to say the Part P course makes me an electrician.
Does the earth for the SWA only go through the SW, as most cables are 2 core?
Obviously there is RCD protection at the CU, does the incoming supply need any form of local isolation in the garage or fused spur?
Does the above all sound ok?
Cheers, Sam
Cheers, Sam
