Hi Again,
Thank you very very much for your reply, I 'am in Cheshire. This job was done 4 week's ago, I complained on the second day before they finished at noon, that the new rads were not hot, two days later the boiler got very very hot, the pressure dropped to one digit off zero and the copper pipe outside must have let off steam or water and the bricks were saturated beneath it.
As the engineers would not return, I called out worcester on a one call out fee, the engineer said it had overheated, the wall was black at the side and also the ceiling above it, he checked the flue as it is an open flue and then carried out his investigative tests. He opened a valve on the top of the boiler and a tremendous amount of air started to come out for a very very long time. He did say that wasn't right and it shouldn't do that for that length of time. The diagnosis on that day was a fault on the system, probably sludge in the pipes and it would benefit from being flushed out with x400? or something similar, this was only a recommendation and he would not put it in writing.
As a gesture of good will, he replaced the pcb board.
Thank you very much, I have checked the gas safe register from your link and this person only has a four digit gas safe registeration number, the rest appear to have six digit numbers, with a couple having five digit numbers.Have you see his Registration Card?The engineer that fitted the new rads, (seven in total) with two additional rads added to the system, is a gas safe, corgi registered Heating Engineer and Plumber.
If not, have you checked his registration at Gassafe Register?
Corgi registration means nothing now.
Thank you very much, I have checked the gas safe register from your link and this person only has a four digit gas safe registeration number, the rest appear to have six digit numbers, with a couple having five digit numbers.Have you see his Registration Card? No I haven't seen his registeration card.The engineer that fitted the new rads, (seven in total) with two additional rads added to the system, is a gas safe, corgi registered Heating Engineer and Plumber.
Does it depend on how long one has been registered, as to how many numbers in the registeration? or is it something one pays for and renews each year? Sorry to trouble you further.
HELP!! Can anyone advise and confirm if 22mm copper pipe is compulsary to use for the flow and return from a combi boiler for the heating system, would be grateful for any help regarding this pleaseThank you very much, I have checked the gas safe register from your link and this person only has a four digit gas safe registeration number, the rest appear to have six digit numbers, with a couple having five digit numbers.Have you see his Registration Card? No I haven't seen his registeration card.The engineer that fitted the new rads, (seven in total) with two additional rads added to the system, is a gas safe, corgi registered Heating Engineer and Plumber.
Is it ok to use 22mm for the first metre and then reduce down to 15mm all in copper pipe?1st metre off the boiler should be copper.
tamz";p="1814943 said:The outputs shown are an old rule of thumb which was (still is) used and is reliable for std systems where guys fitting them do not have the time to sit down and work things out.
Hi tamz
So what you are saying is, that it does not matter whether the pipe is 100ft long or 10ft long, it will carry the same capacity.![]()
Regards
spraggo
