search update
15 Apr 2005
Yorkshire
How long does it take for the search to re-index? I ask because I have just removed a few posts of my own from the forum, but they still show up on a forum search. In fact I removed a few yesterday but even they still return search results.
Usually edited posts should be re-indexed within minutes. Removed posts similarly. Indexing was an ongoing process rather than re-indexing en mass. However, the indexing process as you may have noticed is not working as expected. This was what was being worked on before I went away and what is my current priority. So once correct indexing begins it should be ok once more. I'll keep you posted once things start to return to normal.
What about posted posts?
This:
finds nothing....
Another manifestation of the same problem, or something different?
As I mentioned above the indexing isn't working correctly at the moment. :cry:
Indexing is back to normal, and is up to date again.
:D
