Ive been using tlc's cable calculator to size up a cable for a shower but there isn't an option to show cable being run inside an uninsulated stud wall ( 5M ) or underneath a floorboarded floor ( 3M ) in an unheated space.
Can I use the "clipped direct to a wall" with no insulation section or would it be better to use one of the "insulated wall" sections ?
The difference means using either 6mm or 10mm cable. and I have access to enough 6mm cable without having to buy any more.
The shower is a 9.5KW unit btw.
