Nothing wrong with my Ideal boiler, to be fair to Ideal all boilers are crap.
Why would you want to... If the PCB is duff, then fit a new one...Unless it is an Ideal PCB in which case, just fit a new boiler
A lot of PCB faults are caused by a bad / dry solder joint, this quite often happens around where multi plugs connect to the PCB as the stress on the joints of the board from the plugs can cause a crack in the solder joints.....I was just wondering what you would look for to suspect a faulty PCB in general....
WHat are the signs to look for etc?
