Replacing Consumer Unit
5 May 2010
Gwent
Morning chaps,
Im going to be replacing an old Fuse type consumer unit with a new MCB one. Im fine with the work becuase its just going to be basically a straight swap Im just not 100% sure what to do with the live side.
Do I have to contact the supplier? Remove the main fuse?
Any advice would be great thanks
The right thing to do would be to contact the supplier for a fuse pull, the wrong thing to do would be to remove the fuse yourself.
If you choose the wrong option then first have a good look around the fuse carrier for evidence of damage, cracks etc as you wouldn't want it to break apart on you!
Pay some attention to the testing - even if it is a 'straight swap' otherwise you might find you spend your life reseting RCD's... :P
Or MCBs if there are loads which don't cause a fuse to operate but will cause an MCB to....
thanks for the advice guys, ill contact their supplier, im not qualified for the inspection and testing but i am pretty confident on the wiring side of it. what tests could i run to check it for myself?
Replacing a fusebox or consumer unit involves far more than that.
The entire installation should be inspected and tested first, as there are always items which require minor (or major) repairs.
