I had my PIR done, the select registered electrician found all was good except that i don't have RCD protecion on any circuit. He advised me to fit the consumer unit with a RCD system. I had a look around and seen that there are different ways to do it. I'd like to get an idea of what is best and at same affordable to post fit a RCD system on my system. Can you help?
Shall I fit any socket circuits individually oy just the main one in the unit?
The electrician talked me through a split board tho it wld be quite a job and costly too. is there a simpler way than it?
Thanks for any input/advice icon_smile.gif
