To me the situation is totally clear that in any normal situation a hob needs a rigid gas connection.
I refused to give a CP12 for a flat where the father was going to connect the hob with a flexible hose. That wasted my time as I was not going to be paid. I had to go later to repair the boiler for the tenant and saw the hob as installed by the father but I never knew if anyone had done a CP12.
Having seen what can happen with a flexible hose in a fire I would never give a CP12 in that case until its been corrected.
I had though that "flexible" and "flexiable" were the same thing and that one was just spelt wrongly ( like the heading of this topic ). Am I wrong?
Tony
A CP12 is not a pass or fail situation. The document is completed and recorded with what you find ie Blocked air vent, and how you left it.
A registered gas installer has a duty of care and a legal responsibillity, as the last man there you carry the can, regardless of being paid £84.
scenario:
go to friends house for dinner and they have very large DFE with no vent, which is noticeed you as the last RGI have a duty of care to bring to owners attention.
If someone subsequently died legally you would be held liable if unable to prove you did take some form of action.
It also applies if you smell gas, as an RGI you are expected to deal with it, getting paid £84 is irrelevant and not a cop out.
A newly installed appliance can never be NCS.
NCS is intended to apply to something correctly installed AT THE TIME but where standards have moved on since.
So it would be wrong to classify something as NCS when it was fitted last week!
Tony
Tony
If I were to issue certificates for bodged work then I would be seen to be approving of unregistered installations.
