Sorry if my original response seemed less than helpful but broad brush posts can be very difficult to answer concisely & can be disproportionately time consuming. There is always more than one solution to any particular problem & individuals will always have a personal preference on what materials they use & how they do things. It’s down to experience, understanding the materials your using & largely common sense, it doesn’t necessarily mean one way is better than another but some skimp on preparation & quality of materials; cheap generally means less reliability & with this stuff you tend to get what you pay for. Plumbers don’t necessarily make good tillers & vice versa & either may not make a good builder. I work to high standards & will do everything if required (I can do electrics but buy that in as I’m not certified); it’s unusual & I’m not cheap but there are others around like me, you just have to find them.
In general terms, this is what I do;
• A proper plaster job is always better than dot & dab plasterboard
• If using plasterboard in a bath/shower room, only use Moisture Resistant
• Always tile straight onto PB; unplastered accepts 32 kg/sqm plastered only 20 kg/sq/m but add 4 kg/sqm for adhesive & grout.
• If you want to plaster MR PB, it must be primed first or the plaster won’t stick.
• If ½ tiling, plaster down to the tile line (wasting in) before tiling don't leave it til after.
• PB (even MR) should be tanked in wet areas but preferable use waterproof tile backer board. Even more important with recessed shower valves as this puts water behind the panel/tanking membrane & any leak/problem with the valve will destroy it from behind.
• If using really heavy tiles, go for Aquapanel (or similar) rather than PB as
Tictic says; it accepts 50 kg/sqm but you can’t plaster it (well you can but you have to prep correctly & know what your doing)
• You don’t necessarily have to batten the walls when using cement based backer boards.
• Fill & tape the board joints before tiling; I use tile adhesive not silicone as not much will stick to it; spread too much of it around & you could have probs. Or use the manufacturer’s proprietary expensive sealer.
• Don’t grout down tiled corners or around shower trays, bead of silicone but after you’ve done the rest of the grouting.
• I prefer to rip up & replace the floor with new 18-25mm WBP ply regardless; thickness required depends joist size, pitch & span.
• Never use chipboard in a bathroom, even green MR
• I rarely over board but if I do, prefer to use 12mm WBP ply minimum; many use 6mm backer boards successfully but I prefer to stick with ply as I believe it gives less chance of failure.
• Prime the back & edges of ply with SBR sealer before laying; do not prime the tile surface unless your chosen adhesive manufacturer recommends it
• If using cement based adhesive, Gypsum plaster must be primed to avoid a reaction
• Never use PVA to prime a tile base or new plaster
• Fix ply with screws every 150mm & with over boarding, screw into the joists (check location of pipes/cables) not just into the top of the existing boards.
• If over boarding, secure existing floor with additional screws first (again watch pipes & cables)
• Lay ply in the largest possible sheet size, support longest edge down the centre of a joist & fit 4 x 2 noggins under any cross joist joints.
• Only use quality trade adhesive & grout of the correct type for your tiles not cheopo DIY products
• If moving sanitary ware around make sure you can get the correct falls, use a sufficient size waste for the job & separate stack connection whenever possible; don’t be tempted to notch the joists & observe Building Regs for pipe work/connections
• Invest in a decent diamond wheel wet tile cutter for Quartz tiles; as
tactic says, they are expensive & you don’t want to be making many if any mistakes.
• Quartz tiles will be very slippery when wet! Check for staining, you may need to use a stain inhibitor before tiling.
Don’t think I’ve missed anything but probably have, come back with specifics if that lot doesn’t put you on the right track.
