Hi guys, we had the above boiler installed in 2003 and up until the last year - 18 months has worked perfectly.
The problem, which the Gas Engineers have thus far been unable to diagnose, is as follows:
(I must stress that this problem is intermittent).
The boiler goes through its usual start-up routine - Click...Click...Click followed by the noise associated with the pilot light igniting; however, approximately two seconds after this the flame will extinguish and the same process will continue again and again and again. The problem is, and I believe this is a very big one - though correct me if I'm wrong, that each time the boiler repeats this process, gas is escaping into the room. Therefore after several attempts the room begins to fill up with gas. According to Baxi, there is a fail-safe to prevent this from happening.
The company we've been dealing with have replaced nearly, if not all, the parts of the boiler.
1) A new gas valve/solenoid was initially fitted; the problem persisted, again intermittently so we did not know that the problem hadn't been solved. (It can be days, weeks or months between failures).
2) A new pilot assembly has been fitted.
3) New PCB (not 100% sure on this)
4)Ignition cables have been insulated as, according to Baxi, this can cause problems.
The company also checked the gas injector (I think) in case any fluff was obstructing the flow of gas, but this did not change anything.
On one occasion I let the boiler try to ignite for up to 2 mins before shutting it off from the main switch in the airing cupboard. Despite this the boiler still refused to ignite.
The problem can be rectified by turning off the boiler as mentioned above and waiting 3-4 minutes.
I'm now so stressed by all of this and just want the problem sorted. Due to our fear that the house may go up in flames, whenever we go out we end up turning off the Central Heating. I would appreciate any advise anyone may be able to give.
