Hi All
Was hoping any saunier duval specialists could help me.
I have a Saunier Duval Themaclassic F30E Fanned Flue Combination Boiler G.C. no 47-920-36!
I've been getting no hot water for the past 2 months or so. Central heating works absolutely fine.
Now after advice from you guys, i checked the diverter valve. it was very stiff so i removed the valve, and the valve had black deposits on it. I cleaned it up using cleaning solution. Vavle looked very nice and clean, most of the black was gone, pin was moving pretty freely, but i used some WD40 also just to help.
Put the DV back together, tried the boiler. Central heating is fine. However still no hot water.
What i have noticed now though is that the water is not AS cold as it was. its not warm, just not as cold. And for a second or two, i get a bit of hot water, then warm, then back to "not as cold" as it was before.
If the problem if the DV, would the fact i cleaned it up to almost new looking not have made any different to the performance??
Diagram of parts and part number is found here http://www.saunier-duval.co.uk/spar...doc=Exploded views&var_doc=300402050028H29,21
