Hi, I wondered if anyone could help?
I have layed a parquet floor (not finished) and some parts of it are creaking where the blocks are moving when weight is applied.
We used a double herringbone design with oak blocks which are 70 x 266 x 20. We started with a 4mm plywood base on the subfloor which is floorboards and nailed through the tongues, putting six nails in each block before moving onto the next.
Will the creaking stop? Will the sanding, filling and applying of Hardwaxoil cure it?
