Hi there,
We recently had some plumbing, and re-tiling work done for us in a holiday home which is an old converted building. After one week of being occupied, about 6 weeks later, we discovered damp patches up the walls which continued to grow until we turned the stop tap off. There has been no freezing weather there for months.
We got the guy back in and he found a split in an original copper pipe (in a 10cm length of pipe between two soldered 90degree bends), under the tiles which he had laid. He had attached new pipe work to the existing copper pipe either side of this old joint, (approx 30cm one side and a meter away on the other), in order to fit a new bath & shower. We are now disputing whether the split was caused by his work or not.
The original copper pipework was done when the building was converted about 12years ago and there has never been a problem with any leaks at all.
In the period just after he did the work we had a slight leak under the new kitchen sink (which he plumbed up) due to a rubber washer not being seated properly, which I fixed myself. He claims that due to the turning on and off of the stop tap an air lock got into the system which somehow caused the split (i.e. not his fault).
The stop tap is under the kitchen sink, the bathroom is about 8-10 meters away from the sink and downhill from it.
Can this happen? Or is it feasible that this split could be caused by anything other than the work he did, or directly as a result of it?
Hope you can help - we just want to hear what some other experienced people think about this before we go any further.
Thanks in advance
Thanks in advance
