Hi We have a Triton Ivory II 9.5kw electric shower which has been working a treat for the last 5 years or so but it has now developed a strange, repeatable - almost like clockwork - problem.
The shower works fine for about 8-9 mins then cuts out and the water stops flowing. The red light is still on at the pull cord and also on the shower itself. If you then switch the shower off at the shower and the pull cord and leave it a while, it works again.
Firstly, a bit of background to how I cared for the shower. A friend told me years ago to every so often after a shower, run the shower on the cold setting with the showerhead off of the hose as this will help flush out the limescale. I have been doing this for years and the amount of limescale that comes out of the hose every time is amazing. Just loads of it.
Initially, I thought it was the thermal cut-out kicking in - so I ran the shower on the Cold setting so that the thermal cut-out wouldn't be needed (is this correct?) but the shower still stopped after a short time, so I don't think it is the cut-out, is it?
I also did some googling and there were a couple of suggestions about running the shower without the showerhead on, in case there is a build-up of limescale in the showerhead causing back pressure. So I tried this but still the same problem of the shower cutting out.
The only other thing I can think of is to check the Inlet filter to see if that is blocked at all - as it may well be after 5 years use, I guess.
it just seems strange to me that the shower does work, but only for a few minutes at the time.
If anyone has any suggestions that I could look at (my Dad's an electrician if that is any help) that would be greatly appreciated, as right now we really can't afford to buy a new shower.
Many thanks in advance,
Face
Face
