no power to shower - help!!
23 Jun 2010
Bristol
Our shower recently stopped working, I presumed it was a fault with the shower and replaced it. Got a couple of uses then stopped working again, then after a couple of days started working and then stopped again.
The shower has a pull switch which when on shows a red light but there is no power light on the shower when this is switched on.
I suspect I may have changed a shower when there may be a problem somewhere else?
I have also recently taken off the pull switch and re-tightened all the terminals and now, there is a dim light on the shower (when the pull is on), but this goes out when the shower is switched on and still no water.
Can anyone suggest anything? Should I change the pull switch?
watched England win, then went to get a new pull switch and hey presto, works a treat.
Thanks very much.
