    Dismiss Notice
no power to shower - help!!
Discussion in 'Plumbing and Central Heating' started by johnyr, 23 Jun 2010.
  1. johnyr
    johnyr
    23 Jun 2010
    2
    Thanks Received:
    Bristol
    Country:
    Our shower recently stopped working, I presumed it was a fault with the shower and replaced it. Got a couple of uses then stopped working again, then after a couple of days started working and then stopped again.
    The shower has a pull switch which when on shows a red light but there is no power light on the shower when this is switched on.
    I suspect I may have changed a shower when there may be a problem somewhere else?
    I have also recently taken off the pull switch and re-tightened all the terminals and now, there is a dim light on the shower (when the pull is on), but this goes out when the shower is switched on and still no water.
    Can anyone suggest anything? Should I change the pull switch?
  2. Sponsored Links
  3. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    pull cords knackered. probably burnt connections in the pull cord.
    common fault.
    • Thanks Thanks x 1
  4. BournemouthPlumber
    BournemouthPlumber
    21 Jun 2008
    133
    Thanks Received:
    21
    Bournemouth
    Country:
    Agree with Mr Seco.
    Hope you kept all the packaging for the new shower :rolleyes:
  5. johnyr
    johnyr
    23 Jun 2010
    2
    Thanks Received:
    Bristol
    Country:
    watched England win, then went to get a new pull switch and hey presto, works a treat.
    Thanks very much.
  6. seco services
    seco services
    3 Dec 2007
    15,701
    Thanks Received:
    1,260
    Essex
    Country:
    i'd rather of fixed me shower.
  7. Red_Man
    Red_Man
    26 Jan 2008
    126
    Thanks Received:
    6
    Country:
    He done both though!? :rolleyes:
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
