First thing to point out, I'm not Gassafe.
I was working at a customer's house today, routing a new cable through the ceiling above their Concord WRS heat-only boiler, whilst standing on a ladder. Happened to notice that the casing/cover wasn't fitting closely on the top, on the left side. I pushed it in a bit towards the wall hoping it would fit better, and it nearly fell off.
The cover is held on by two clips at the top with wing-nuts on them. The left hand clip is broken, which is why it wasn't pulled in tight to the main body. Also, the bottom of the casing has a captive bolt thread on each corner, which should have a nut holding each one. The nuts are missing, and the bottom of the cover is unsecured.
So basically, the cover only has one top bracket that is actually holding the cover on. As its a balanced flue, is this safe? The boiler is used daily, for hw at present.
Are new clips to replace the top broken one still available?
