I am buying a flat, and the home buyer survey just came back.
The surveyor states that "hot water is provided by a Sadia Megaflow Moonsoon sealed and vented system, providing hot water at mains pressure. There is an associated Sadia pump and expansion bottle. Pressure was low at time of inspection. Pump was turned off due to noise during the night. The bath and wash hand have fairly low water pressure without the pump pressure. The pump didn't operate immediately when switched on and therefore should be inspected. Water pressure in the kitchen sink was fine".
I was told initially by the seller that there is a pressure pump, but it's not really required and they disabled it. The flat is in a modern, high specification building built 7 years ago.
I am confused by all of this:
1) I can't find a cylinder called Megaflow Moonsoon vented. I can only find Sadia Megalo unvented, and a separate ST Moonsoon pump. Is he just confused?
2) Did they install a pump just for high shower pressure? I thought unvented systems were supposed to provide more pressure?
3) Should the pump start on demand? Is it just fine to turn it on and off (power switch), or is it likely to damage it? Is it more complicated than this to bypass the pump?
4) Should the pump make some noise during the night, even when unused? I am reading that ST pumps are supposed to be the quietest. I don't understand why the pump would work all the time.
5) If I had to replace the boiler and the pump, what would be a typical cost including installation. Is there a quiet, efficient better solution for high pressure (shower).
Sorry if I am asking obvious questions, but I am new to all of this.
Many thanks.
Tom
Many thanks.
Tom
