Have had a whole host of trouble with the toilet recently, mostly leaking from the hex nut that joins the inlet pipe to the ball valve (metal nut to plastic thread)
First replaced the fibre washer in the nut, as it had corroded, everything seemed ok, then about a year later, same problem. changed washer again as it had gone funny. reconnected but still leaking. Figured the nut may have crossthreaded the plastic of the ball valve, or cracked it, so replaced that. Everything seemed ok. Came this morning to a steady dripping from the same area yet again. Tightened the nut ever so slightly, and the drip turned into a trickle, water is currently isolated so as so stop any floods of the loo.
The pipe is solid all the way(no flexi hose)
