Runnig Satellite Coaxials before plastering
Look, you do it like this...
The simple loft box is really just a glorified splitter. It's not complicated at all.
Just make sure you have the aerial feed from your loft or roof aerial going to the Sky box, then take the output on the RF2 socket and send it up to the loft box. From the box you then have a wire going to each TV. It's easy-peasey-pooh
Thanks Chris, Got it now. Only difference is im going to run the satellite coax inside because ive got a bay window above the obvious point of entry. Thanks again for your help.
Martin
