wall plate size question
28 Jun 2009
Nottingham
Hi all.
I am just finishing the brickwork for a rear single storey extension.
I will be starting the lean to tile roof construction this week hopefully.
I want to know what size the wooden wall plate should be that sits on the inner block wall that suports the roof rafters.
I am struggling for roof angle (15 degrees) so wondered if 25mm thickness is Ok or if it has to be thicker.
I concur with Middleagedfella, 25mm will be practically useless and prone to splitting. You need a bit of meat when fixing joists and rafters so close together.
