Hi There, can anyone help.
My wifes 55reg Megane has developed an intermittent starting problem.
When you push the button it starts, coughs and splutters and then gives up. When you try it again it normally starts but on a cold morning it can take 3-4 attempts. Not long ago the emissions light was on and a friend (mechanic) told me he would reset this and everything should be fine. Could this be the problem?
Also there is a white plastic ring around the inside of the steering collum that had come loose and made a ticking noise when turning, he also tightened this up and when steering the noise had gone but it felt like something was going to snap. Now the drivers airbag light is on and eventhough the passenger side airbag has been turned off this does not show on the dashboard. I think that this is all down to my friend (mechanic) doing the work above but just wanted to know if someone can confirm and any advice to how I speak with him as I have known him since I was 5. Thanks, Phil
